Engine Problems - Mechanics don't know
Old Jan 30, 2010 | 09:38 AM
Scotty2H's Avatar
Default Engine Problems - Mechanics don't know
Hey guys, having some problems with my ITR. Posted in the ITR section, but though there might be some other bright ideas around. Here's the link. I'm lost
https://honda-tech.com/forums/showth...7#post41413277
Any help would be appreciated.
Old Jan 30, 2010 | 12:52 PM
jdm inc's Avatar
Default Re: Engine Problems - Mechanics don't know
sounds like the TPS sensor is bad.
How do your plugs look?
Old Jan 30, 2010 | 10:08 PM
RC000E's Avatar
Well, honestly there isn't much to figure this kind of issue out. Many codes won't be triggered because the sensor in question is still scaling, just not accurately. TPS can jump voltages, causing driveability issues, but it's still reading so the ecu doesn't see the issue.
Fact is, if your "mechanics" can't figure it out then they're dumb asses and go somewhere else. Simple test procedures can be done to ensure the tps and map are functioning correctly, from there I'd run it on my computer and just watch all the inputs to find the issue.
I could fix that car easily and that doesn't mean I'm necessarily special, it just means your dealing with people who aren't capable or equipped enough to handle the problem. Anyone can sit here and guess what your problem is, but the fact is someone locally needs to put their hands on it and figure it out. This forum isn't gonna do much other than speculate.
If you want advice, then buy a multimeter and a Helms and start troubleshooting. If your not capable of handling that, then take your car somewhere more reputable. Issues like these aren't hard to figure out if your dealing with someone that truly understands EFI systems. If they are guessing then they're nothing more than robots doing basic mechanic work, in which case move on.
Old Jan 31, 2010 | 02:49 PM
hondamark35's Avatar
i second that. well put
Type rawr
Jan 22, 2011 07:52 AM
Rastaman
Jun 8, 2009 04:36 PM
nickcrx
Oct 6, 2005 04:33 PM
homeskillet
20
Jan 10, 2005 02:28 PM
ThomasMassengill
Sep 14, 2002 01:02 PM
