VTEC HELP!!!
Old Jan 30, 2010 | 07:03 AM
NiKKa NiKKy's Avatar
Default VTEC HELP!!!
ok, i got a 1997 civic ex coupe, it has a jdm b16a obd0 motor BUT the whole cars wiring was converted to obd2 so i am running a the big p2p ecu. by the ecu on the middle socket, there is a blue/red wire and a white/red wire that are cut and opened. the blue/red wire connects to a spliced yellow wire. the white/red wire connects to a spliced black wire. i got the car like this and i dont know why they did this? help me please!!
Old Jan 30, 2010 | 08:12 AM
Default Re: VTEC HELP!!!
pllease help!!
Old Jan 30, 2010 | 12:07 PM
delsolproblems's Avatar
You haven't said that you have any problem. If the motor is running fine and you just want to know why the wires are spliced, you should get a pinout diagram for your ECU and then follow where the wires lead.
Old Jan 30, 2010 | 01:25 PM
oh lol my bad, well the vtec isnt hitting, two days ago it was? what could be the problem. ad i have a really bad case of cold start.
Old Jan 30, 2010 | 04:06 PM
Replace the thermostat if it hasn't been replaced recently. Vtec won't engage if the engine isn't up to normal operating temperature. You can also check the motor's temp to see how well it's warming up.
Old Jan 30, 2010 | 04:39 PM
HondaPartsHero's Avatar
Technical Hero
I think they were trying to do this:
http://www.ff-squad.com/technet/ckftrick.htm
Old Jan 31, 2010 | 11:54 AM
do i cut in between the ecu and socket or after the socket?
Old Jan 31, 2010 | 12:04 PM
after i fix that should my vtec work? it has been rea; cold here lately but my car says its warmed up before i try to hit it. but yea i dont know where to cut in details. because depinning it means the same as cutting it in between the ecu and quicksplice right?
I_dont_want_a_user_name
Dec 23, 2006 04:29 PM
MotoCARR
11
Dec 21, 2006 01:03 PM
b16ahybrid
Mar 7, 2004 08:52 PM
