2000 honda accord heater problem
Old Jan 29, 2010 | 09:18 PM
smile_78905's Avatar
Default 2000 honda accord heater problem
Hi everyone
This is the best site ever to ask any questions, so here they are....
My honda accord's heat will only work when it's on the highest setting, what's wrong with it? And no it just doesn't blow anything unless the dial is on high then it will start blowing out other than that I can't control how high or low I want the heat to come out.
My abs and srs light is on as well anyone have any suggestions w/out me having to go to honda and spend a fortune?
Thanks everyone
Old Jan 31, 2010 | 01:10 AM
Default Re: 2000 honda accord heater problem
anyone?
Old Jan 31, 2010 | 09:02 AM
nus_dogg's Avatar
You probably have bad resistors from low to medium except for the high speed resistor that isn't blown. I'm in electrical class right now, and thats what I learned if low & medium isn't working.
My ABS & SRS light was on too. I have an aftermarket str wheel so that caused the light to come on and my ABS light was on for some reason and I removed both bulbs behind the cluster gauge.
c172jeff
Suspension & Brakes
Aug 17, 2018 06:19 AM
KitKat691
May 30, 2018 08:42 AM
00n0908
Sep 11, 2016 09:39 AM
