Transmission & Drivetrain Gearboxes, Differentials, Clutches
Loose shifter even in gear...?!?
Old Jan 29, 2010 | 05:56 PM
forcdincivic's Avatar
Default Loose shifter even in gear...?!?
So i Just picked up a 93 ex coupe 5-speed. Stock tranny, motor, etc. As I drove it home I realize how loose the shifter felt. Even when in gear it felt like it was in nuetral. It would move to left and right at will with no real friction. In any gear it did this, all while still staying in gear. Are there any bolts that could be tightened? Maybe replace the linkage. I just got home and havent had a chance to throw it on the lift yet to see if anything is loose under there but just wondering if anyone else had this same problem at one point. I searched and found nothing so if anyone could throw some ideas that'd be great. Thanks
Old Jan 31, 2010 | 08:54 AM
jonnyt1130's Avatar
Default Re: Loose shifter even in gear...?!?
shifter/linkage bushings. buy some new ones and it will be nice and stiff in gear
Old Jan 31, 2010 | 03:32 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
on the shifter there's a little ball between your shiftknob and where it bolts to your linkage, around that is supposed to be a plastic piece. you're missing that
Old Jan 31, 2010 | 04:31 PM
shazaam's Avatar
^ +1
like jonny said bushings could be shot also. n if you can pull it out of gear that'd be synchros.
Old Jan 31, 2010 | 05:35 PM
stevenDAtegra's Avatar
Get some energy suspension bushings and it'll feel nice.
Old Jan 31, 2010 | 06:24 PM
thanks for the responses guys. ill check that out. very helpful
Old Feb 4, 2010 | 02:09 AM
95_Civic_4dr's Avatar
x2 on that
I replaced my stock bushings with those and I loved the difference, can't believe I was driving on the stock ones for so long.
HopelessAccord
Nov 20, 2018 07:11 PM
Concept Tuning
May 11, 2006 10:35 PM
h22pwr
Jun 7, 2005 11:33 AM
rough_draft
May 9, 2004 10:53 AM
cr-x si
Jun 11, 2003 09:06 PM
