rims size HELP
Old Jan 29, 2010 | 05:09 PM
j_mee_5's Avatar
Default rims size HELP
oky so i picked a rim that i wanted to get..
but they are 16-8 and the pattern is 4x100.. i know that it will fit but was wondering.. about the weith of the rims. since its by 8 i was wondering will it scrap the finders or be a problems of any kind.. thanks guys..
if you are just replaying to bash on me please dont thankyou..
Old Jan 30, 2010 | 02:01 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: rims size HELP
You can use 16x8 rims on an Integra but you will have to get 215/45-16 tires for that width, which is too wide for 205/45-16. With 16x8 and 215/45-16, you shouldn't rub as long as your car isn't really slammed (lowered a lot), assuming the wheels are the proper offset to give you the maximum clearance in the wheel wells.
Tire availability is very limited in 215/45-16. That's why 16x7 is a better bet for Integras; you can use either tire size and that gives you far more tire options. And 205/45-16 will give you a bit more clearance in the wheel wells, which may be important if your car is lowered.
ericneff9
Mar 28, 2014 07:19 AM
tyronne1126
Honda Civic (2006 - 2015)
23
Mar 30, 2009 12:58 AM
snapper1978
Oct 26, 2006 10:09 AM
JDMRice
Jun 18, 2005 07:27 AM
JDM_Powered
12
Nov 21, 2004 06:44 AM
