I need your input on crx upgraded sway bars!?
Old Jan 29, 2010 | 03:59 PM
draginmywagon's Avatar
Default I need your input on crx upgraded sway bars!?
hey i hope im posting this in the right area, if not sorry! well i have an 88 crx with upgraded suspention nothing to crazy just tokico struts,skunk 2 lowering springs, blox lca skunk2 camber kits blah blah blah. i just wanted peoples openion on upgrade the stock sway bars cus im thinking of doing auto x, any info would be grade. thanks!
1. is it worth it? and did you notice any big changes?
2. did you do front and rear? (if so what size)
3. what set up are you running? (pix are a plus!)
feel free to post pix!
Old Jan 29, 2010 | 04:03 PM
Driven's Avatar
Default Re: I need your input on crx upgraded sway bars!?
best advice ever:
1. run an autocross as stock as possible until you know how to drive and how everything works and how changes affect what.
2. repeat step 1.
regarding your questions:
1. no, not unless you know what's happening with the suspension.
2. left them stock until I knew what I was doing.
3. stock... until I knew what I was doing. pictures won't help you determine which sway bar set is best
Old Jan 29, 2010 | 04:20 PM
.Manny.'s Avatar
Touching My Member
all stock swaybars until I get track time under my belt.
Old Jan 29, 2010 | 04:58 PM
CRX Toad's Avatar
Originally Posted by Driven
best advice ever:
2. repeat step 1.
And Manny has it correct. Listen to these guys I agree with them 100%
CRX831
Feb 19, 2010 08:20 AM
SiRay13
Suspension & Brakes
Jan 22, 2006 07:59 PM
JDM Panda
Suspension & Brakes
Aug 3, 2005 02:47 PM
bluef
Oct 24, 2002 08:05 AM
bluef
Oct 23, 2002 11:08 PM
