S2 70mm throttle body and Euro-R manifold question
Old Jan 29, 2010 | 01:19 PM
shahriar35's Avatar
Default S2 70mm throttle body and Euro-R manifold question
I am curious to know if the 70mm Skunk 2 manifold would fit an euro-R manifold or would the TB stick (meaning would the butterfly get stuck)? Thanks
Old Jan 29, 2010 | 04:28 PM
GhostAccord's Avatar
Default Re: S2 70mm throttle body and Euro-R manifold question
Are you asking if the skunk2 throttle body will fit on a Euro R manifold?
If you are,
What's the sense of having a 70mm throttle body on a stock intake port? You should bore the intake manifold out to match the throttle body no matter what. Not port matching them would cause a step up that would kill any gains that you might gain going to 70mm.
An S2K throttle body and port matched Euro R manifold would be a much better match.
Old Jan 29, 2010 | 07:49 PM
shahriar35's Avatar
If you are,
Oh I understand that. I want to get the throttle body so that I can have it machined. I just want to make sure there will be no problem with sticking and it will clear everything when its bored out. I think I should stick with a 68mm
Old Jan 29, 2010 | 08:12 PM
Yeah from what I have seen 68mm is the max bore for the Euro R manifold.
Old Jan 29, 2010 | 08:17 PM
shahriar35's Avatar
I spoke to Rosko Racing and they said 70 is cutting it close so I will stay w/ the 68mm
Old Jan 31, 2010 | 12:13 AM
nus_dogg's Avatar
and I heard multiple problems with the 70mm TB when 68mm has less problem. Mine's a 68mm S2 TB, and it does stick around 1.5K at times after I drive it for more than an hour.
firstgen225
Jul 21, 2012 06:49 AM
blackoutvtec845
May 11, 2010 05:49 PM
Phatch99
Jun 10, 2004 07:14 AM
JforJonathan
10
Apr 10, 2004 12:15 PM
