Pulling out shift cables from 94 Accord transmission??
Old Jan 29, 2010 | 10:43 AM
Greatness's Avatar
Default Pulling out shift cables from 94 Accord transmission??
I removed the all the cotter pins but the shift cable still is attached to manual transmission on my 94 Accord LX. Is there anything else I need 2 remove??
It seems to be attached to like a bracket of some sort.
Old Jan 30, 2010 | 07:22 AM
Greatness's Avatar
Default Re: Pulling out shift cables from 94 Accord transmission??
Anyone?
Old Jan 30, 2010 | 01:18 PM
davey5300's Avatar
yup theres a bracket thats bolted onto the tranny that the cables are clipped to. if' your trying to drop the tranny you can either A: pull the clips with plyers or vice grip, or B: Unbolt the bracket from the tranny. The bolts are all under neath the lower radiator hose and wire harness so you'll have to kinda look for them. there's 3.
Old Jan 31, 2010 | 09:32 AM
Greatness's Avatar
thanks
Old Jan 31, 2010 | 09:51 AM
GhostAccord's Avatar
Old Feb 1, 2010 | 08:16 AM
Greatness's Avatar
Originally Posted by GhostAccord
THX MAN God I appreciate the help from all You GUYS!!!! This project would have been impossible without the help from you guys!!!
Old Jan 13, 2011 | 05:26 AM
Dfischer94's Avatar
Icon2 Re: Pulling out shift cables from 94 Accord transmission??
I have the shop manual with the exact picture that has been posted on here. But I cant seem to find where that cable bracket is. It looks like the shift cables are behind the block like under where my intake hose used to be, but im not sure. Can anyone help? Thanks in advance.
Old Jan 13, 2011 | 03:31 PM
It is located on the top of the transmission pretty much directly under the thermostat housing/to the left of the distributor and down. You will need to remove the intake tube in order to get at it.
Greatness
Jan 23, 2010 04:03 PM
BoostedH23Accord
Mar 6, 2007 12:11 AM
