D15B7 head?
Old Jan 28, 2010 | 04:16 PM
88EDHatch's Avatar
Default D15B7 head?
will a D15B7 head work on a b2 block without changing anything over?
Old Jan 28, 2010 | 08:16 PM
88EDHatch's Avatar
Default Re: D15B7 head?
bump
Old Jan 28, 2010 | 08:38 PM
Eighty-Nyne's Avatar
Yes. Well not technically.
You can reuse your DPFI manifold on the b7 head just fine.
If you want to use the b7 mpfi setup, you have to do an mpfi swap.
Next time just type your question into google.
Old Jan 28, 2010 | 09:04 PM
88EDHatch's Avatar
yeah i want to keep it dpfi for now then rebuild it a couple months down the road and do the mpfi swap and maybe boost it
Old Jan 29, 2010 | 04:53 PM
freon480crx90's Avatar
head swaps with no problems its the same head
Old Jan 29, 2010 | 05:25 PM
Then it's the same.
Just swap your old manifold and dizzy on the new head, can even use same timing belt.
Same head code, pm3.
low&slowef
Jun 13, 2011 10:11 AM
mikej94civex
Jan 11, 2010 02:20 PM
Nate13
15
Dec 16, 2009 10:50 AM
