D16Y7 S0HC - non vtec
No more rain in So Cal so today, I put back in the cold air intake.
When I remove the intake tube I see engine oil inside the tube, Is that normal?
Thank you
Thank you
i dont think it is because every honda motor ive went through it didnt have oil in the intake tube. but i did have one dual point motor that had oil in that black dpfi thing.
Yes it is normal at high RPM's oil comes out of the breather on the valve cover and goes into the intake tube. Usually you want see any oil since it gets suck into the motor. You may want to check your PCV valve to make sure it is still good also make the black box on the back of the block isn't clogged.
fred92htch
11
Apr 14, 2003 01:19 PM
