91 Ef Si swap help.
Old Jan 28, 2010 | 01:00 PM
RobotRob's Avatar
New User
Default 91 Ef Si swap help.
Ok I have a 91 Si. I want to swap an LS motor with a hydraulic tranny into it. I know i need motor mounts, jumper harness?, and a hydro tranny conversion kit. But what i dont know is what jumper harness do I need. (is it the same harness for a 96 LS and a 00 LS motor?) Also do I get the tranny conversion kit for a DA to DC? Or which one?
Please list anything else I need.
thnks!
Old Jan 28, 2010 | 01:11 PM
D16SiHatch's Avatar
Default Re: 91 Ef Si swap help.
search! check out the faq thread at the top of this forum
i'm not going to spoon feed you everything you need, but i will answer the other specfic questions you had. i presume you will be running obd1 so you will need an obd0 to obd1 jumper, like so.
http://rywire.com/store/8891-crxcivi...04c8fbd50a02e7
you get the tranny conversion for an ed/ef seeing as how everything else 92 and up (eg, ek, ej, etc) is already hydro to begin with.
http://hasport.com/store/index.php/a...ch/efbhcl.html
to use the b-series trans you will also need an appropriate shift linkage
http://hasport.com/store/index.php/a...e/efblink.html
Nateman2
Jul 18, 2016 01:47 PM
88 EF Hatch
Feb 27, 2009 12:50 PM
Lil Gnome
Dec 31, 2008 12:23 PM
93dagsr
Jul 9, 2008 03:38 PM
Bseries!EF!hatch
May 19, 2006 08:24 AM
