Mpfi snafu
Old Jan 28, 2010 | 10:33 AM
Holyoly253's Avatar
New User
Default Mpfi snafu
So, this kid at my shop did a mpfi swap with really doing much research. We've been banging our heads trying to figure out what he did wrong. Basically at this point whats happening is the engine won't rev over 3 grand. I've been looking at some of the "diy write-ups" on this swap and there seems to be variance between the couple I've read. If anybody has come across this issue and found a solution let know.
Old Jan 28, 2010 | 10:34 AM
Radim's Avatar
Default Re: Mpfi snafu
Check what codes it's giving you.
Old Jan 28, 2010 | 10:45 AM
DCRB's Avatar
ugh mpfi isn't that hard. it's running four new wires from the ecu, removing one plug from the engine harness, adding mpfi injector plugs, changing the dizzy plug, making sure the two wires from the dizzy are hooked up correctly (blue with a green stripe and blue with a yellow stripe i believe) and hooking all their yellow wires up to one or two yellow wires or a resistor box
i've used this right up multiple times, my car had zero problems till the motor blew up, and my buddy's 91 std is still running strong
http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
Old Jan 28, 2010 | 11:07 AM
HondaPartsHero's Avatar
Technical Hero
SWITCHING THE WIRES AT THE TPS:
This pretty much explains itself, just switch the two outside wires(green/white and yellow/white) around at the TPS and then you're done this step.
Did he do this?
Old Jan 28, 2010 | 11:50 AM
Holyoly253's Avatar
New User
Ok, so right now no codes, we've switched the wires on the tps sensor and, thanks for the write i'll go through and see if there something on that. We've triple checked all the wiring that we've done to make sure things are working. IDK i thought maybe there was some bad component
EDIT: So i just found out the dumbass isn't using a si resistor box and I'm not even sure if he has the right ecu.
19Honda91Sedan
34
Jul 3, 2012 09:35 AM
thatHEMIguy
Mar 4, 2010 08:57 AM
redboy183
Dec 23, 2007 09:50 AM
Nextelbuddy
Jun 12, 2005 06:12 PM
88rexdxa6ed
14
May 6, 2003 01:56 PM
