Comptech Lower Tie Bar/Sway
Old Jan 27, 2010 | 08:24 PM
NteGSR2o9's Avatar
Default Comptech Lower Tie Bar/Sway
Hello guys,
I own a 1998 gs-r and just picked up 2001 type r. I'm in the process of deciding which parts to swap over from the gs-r to the type r. I was wondering if the comptech rear lower tie bar/brace is compatible with the type r and the oem sway bar? I would love to keep the bar if it's compatible.
Old Jan 28, 2010 | 08:02 AM
cheezthis's Avatar
Default Re: Comptech Lower Tie Bar/Sway
The Comptech bar is 22mm, which is also the same as the stock usdm bar. The tie bar is not compatible, your type-r has one already too.
Keep those on the GS-R...
Old Jan 28, 2010 | 10:36 AM
94rs-turbo's Avatar
nope keep the bling parts on the gsR,
Old Jan 28, 2010 | 08:51 PM
NteGSR2o9's Avatar
Thanks for replies. I'm selling my GS-R and would like to keep some of the compatible "bling" parts. Too bad my comptech ice box won't fit either! As you can see, I like comptech, but nothing fits on my type R.
Old Jan 28, 2010 | 09:05 PM
cheezthis's Avatar
The icebox will fit fine if you use the stock intake arm. You can definitely do that, and it will work quite well. Just use the stock intake arm...
Nothing wrong with what you did with the GSR, I owned a GSR for many years. If you're selling it and cannot put the stock parts back on, sell the comptech sway/tie with it. However, you can definitely transfer the icebox (box and intake velocity stack) over to any Integra.
Old Jan 28, 2010 | 09:08 PM
EFsSuck's Avatar
correct.... i sold mine when i bought my R.
kcjohnnyboy
Suspension & Brakes
30
Aug 27, 2007 01:10 PM
96gsrvtec1986
Apr 9, 2005 07:31 AM
hondamanwill
Mar 15, 2004 08:22 AM
JDEM1
Nov 6, 2003 03:36 AM
Trigun
May 29, 2002 09:36 AM
