Swap help!! B18c into HF
Old Jan 27, 2010 | 07:10 PM
bseries94's Avatar
Icon3 Swap help!! B18c into HF
I just picked up the swap which is a b18c.
The guy gave me a set of mounts but they don't fit the swap. The bolt holes do not line up on the trans. Therefore I beleive all I have to do is buy the mounts for a hydraulic trans, but before I do that I'd like to know if I need to change the mount with the two studs on the drivers side of the engine or will the hydro mounts simply line up!
Second question: the engine lost the vin # and I'd like to know exactly what engine I have, the block has b18c the number right under it is 1909923(if helps), the tranny is a ysk-2.
Old Jan 27, 2010 | 07:15 PM
hatchet_honda's Avatar
Default Re: Swap help!! B18c into HF
you may need the engine bracket from a 90-93 teg on the drivers side mount before it lines up. if your block is only labeled b18c with no numbers right after then you have the ITR block.
Old Jan 27, 2010 | 07:21 PM
bseries94's Avatar
I wasn't sure if I had the spec R or the sir-g
Old Jan 27, 2010 | 07:29 PM
WELL is the block obd2?? is there a crank sensor on the oil pump?
Old Jan 27, 2010 | 07:33 PM
bseries94's Avatar
It is obd11 for a fact
D97
Oct 12, 2014 05:56 PM
ArrizownEM1
Nov 7, 2012 11:12 AM
trojan
Sep 6, 2011 10:10 AM
NZDelsoldude
Dec 20, 2006 02:41 PM
leono
Jun 25, 2005 04:11 AM
