F/S: GSR Eagle Rods/shift linkage/B20Z/alternator/cluster/cruise control+
I have a lot of random stuff sitting around the garage that i have absolutly no use for. Everything is in good working order unless otherwise noted. Here it is. Will possibly ship stuff for free. PayPal or cold hard cash only. Make and offer if the price doesnt seem right!
OBD1 SOHC dizzy $60
OBD0 Dual Point dizzy $35
EF gauge cluster, MT with 156k on the odometer $40
OBD2 alternator. B-series I believe $35
OBD1 D-series alternator $35
Eagle GSR H-Beam rods. BNIB
D-series clutch and pressure plate. OEM i believe. PP needs to be cleaned up $35
LS cams $40
9006 HID ballast with no input plugs, will plug in with any HID bulb though. $25
D-series starter $20
SPC rear camber kit for civic/integra. Painted white. sorta $30
Cruise control from an EG. $5
B20Z complete bottom end. From TallKyle's old EF hatch. Only thing it needs are bearings (lost them) Everything else is there, mains, water pump, oil pump, tensioner, rings, pistons, bolts and all. If you need more information about it, prolly PM him since he never told me anything about the car. Ran flawlessly, crashed vehicle and broke the mount off the block which is why I took out the internals. $Make offer
After market DC2 sideskirts. They are plastic. $50
Random Shift linkages. I think majority are d-series. $5 a piece
D-series exhaust manifold
OBD1 SOHC dizzy $60
LS cams $40
reactiondc2
Jun 19, 2006 08:35 AM
