Swap guidance
Here's the deal. I have a friend that swapped out his H23/auto in his Prelude for an H22a. He said he would let me have the engine and trans for $100 since he doesn't need it. I can also get H/EG mounts and axles for ~$300ish. I did a little research on the swap, enough to see that it wasn't the most desirable swap..Anyways does anyone think it would be worth it considering how cheap I can get the parts for? I will look more into it depending on responses, not sure how complex it is. If it's fine I will probably "mildy" boost it and swap in a H22a when it goes.
In my opinion, if you're going to keep it automatic, then it's not worth it. If you were to get a manual transmission, then it'd be worth it, since you can get those other parts for so cheap.
originalkush
May 4, 2007 01:29 PM
