94 accord transaxle shift cable pin removal.
Old Jan 27, 2010 | 12:10 PM
Greatness's Avatar
Default 94 accord transaxle shift cable pin removal.
Well I been trying to remove the shift cable pin known as the ***ch pin or roller pin has been almost impossible to move.
Not knowing what I was getting into I tried to pull it with needle nose pliers. It hasn't budged. Since I've undone the engine mounts... The whole engine lifts up while I try to pull the pin from the top with needle noise pliers.
Seeing that fail. Im trying to beat the pin from under the car with a 8 mm punch and hammer.
Is there a better technique that you guys know?
I appreciate the help.
Old Jan 27, 2010 | 12:32 PM
cstone's Avatar
Default Re: 94 accord transaxle shift cable pin removal.
what kind of pin is it? i dropped the tranny on my sisters prelude a few years ago and it was just a codder pin on that if i remember correctly. if so make sure that it is bent pretty straight. i remember it being a b**** to get out but i got it after getting the end straight.
Old Jan 27, 2010 | 02:29 PM
davey5300's Avatar
cotter pins are such B****s to take off.what I do is Spray it with some WD 40 or PD blaster, then I cut the loop end off and push the rest thru. Replace with a new one
all_motor_mike
Jan 23, 2013 06:08 PM
sobey
Jul 30, 2011 06:41 AM
Greatness
Jan 23, 2010 04:03 PM
LOLO93PRELUDE
May 28, 2008 01:39 PM
BoostedH23Accord
Mar 6, 2007 12:11 AM
