OBD1 95 Integra with OBDII 00 GSR Swap - What Distributor?
i believe you would need the obd2 harness and dizzy, unless you are also running obd1 injectors. if you are running obd1 injectors and harness then im sure you would need the obd1 dizzy..correct me if im wrong
DIYMIKE
Feb 23, 2007 09:06 PM
