* * * Pics BLOX Drag Coilovers * * *
Old Jan 27, 2010 | 09:59 AM
southernSCHEME's Avatar
Default * * * Pics BLOX Drag Coilovers * * *
Any1 have these on their cars? if you do, please drop a pic..
I'm in the process of ordering a set but i would like to hear from the Tire Tuckin' Community
Old Jan 27, 2010 | 03:47 PM
redrota24's Avatar
Default Re: * * * Pics BLOX Drag Coilovers * * *
i just got a set of these at christmas time. if you drive it everyday get the tuner series bc they are stiff as ****. other than that i like them a lot. im low as hell and dont bottom out
Old Jan 28, 2010 | 06:24 AM
any pics??
any1 else with some feedback on these??
Old Jan 28, 2010 | 06:51 AM
portenio78's Avatar
I have these on my Del Sol, but its not lowered that much because I have it setup to clear slicks. Over all I really like this suspension. Its pretty crazy stiff on the streets.
Old Jan 28, 2010 | 07:03 AM
01-0720's Avatar
op why would you get a drag specific coilover setup, just to dump your car on the ground?
according to this page https://honda-tech.com/forums/wheels-tires-brakes-suspension-48/blox-drag-series-coilovers-limited-supply-eg-ek-dc-free-shipping-2675451/
they have 12k front and 18k rear springs, and the shocks are non adjustable so they are valved for those high spring rates and not to be dumped, there meant to sit higher for clearance and proper weight distribution
18k rear springs are goin to ride stiff and ruff on the street
and if you dump them i can almost guarantee your going to blow those cheap shocks fast
Old Jan 28, 2010 | 09:08 AM
bebe101's Avatar
Competition Series -- FR = 12kg/mm: RR = 10kg/mm
no motor in the car (sorry) best i have at the moment
Old Jan 28, 2010 | 05:29 PM
WHATS THE DIFFERENCE BETWEEN THESE SPRING RATES???
WHICH ONE LETS YOU GO LOWER WITHOUT PROBLEMS.
Tuner Series: BXSS-00100
-Front: 10 kg/mm (559 lbs/in)
-Rear: 8 kg/mm (447 lbs/in)
Competition Series: BXSS-00101
-Front: 12 kg/mm (671 lbs/in)
-Rear: 10 kg/mm (559 lbs/in)
Drag Pro Series: BXSS-00102
-Rear: 18 kg/mm (1,006 lbs/in)
Old Jan 28, 2010 | 10:14 PM
Jdmsoles's Avatar
From: Dodgin Cops all Round Ana-Crime to Orange & Sd
all you list are rates, not spring size, 1st and 2nd ones are more of DD/track spring rate, while the last one like it states are drag/strip rates, as you can see by the 18k rear no squatting what so ever. This wont help you in anyway lowering your car, you need to do more hw.
Old Jan 28, 2010 | 11:32 PM
Sumslapper's Avatar
Year 3030
Oh man those drag ones would just be retarded on the street at those spring rates LMAO. Even there street setup seems pretty stiff at those rates. Considering Ground control is 380F and 250R Off the shelf.
91tegrsjg
Oct 21, 2010 05:26 PM
poptart_ek4
Suspension & Brakes
10
Jan 31, 2009 03:21 AM
mattv
Suspension & Brakes
Nov 10, 2007 12:10 PM
mike93eh2
May 21, 2007 10:52 PM
CLMTFabEG6
Suspension & Brakes
Dec 29, 2005 08:59 PM
