Injector numbering question?!?
Old Jan 27, 2010 | 09:09 AM
djnikko's Avatar
Default Injector numbering question?!?
Hi all, hopefully this is a very easy question but im just looking for confirmation more than anything. Do injectors on all hondas correspond to the cylinder numbers, i.e. cylinder 1 runs injector 1? I know the answer is most probably yes but wanted to be sure as I suspect some wiring issues with my swap and am seeing code 16 (fuel system). I did see a picture somewhere that showed the injectors numbered the wrong way round to the cylinders.
For example the 2 pictures below have reversed numbering schemes.
https://honda-tech.com/attachment.ph...1&d=1232688128
http://www.nobodysuspectsthewagon.com/partialMpfi.gif
Thanks in advance
Old Jan 27, 2010 | 10:35 AM
delsolproblems's Avatar
Default Re: Injector numbering question?!?
The numbers on the injector clips in the second pic are only for reference and do not correspond to the cylinder numbers. It should have been labeled the other way as you noticed.
Old Jan 28, 2010 | 01:00 PM
djnikko's Avatar
Good stuff, thanks for the reply. I just wanted to confirm that was the case.
preludefien
Feb 26, 2007 03:01 AM
mrx
Jan 13, 2004 01:53 PM
jetpilot
Sep 4, 2003 08:28 AM
