b16a 1st gen
Old Jan 27, 2010 | 07:58 AM
hurryup's Avatar
Default b16a 1st gen
i have a b16a in my 91 civic hatch. i need to replace the oil pan gasket, what year and model should i ask for.(I dont know where the engine came from) I want to buy the parts before dropping the oil pan. Someone told me my engine is the 1st generation b16a. Any suggestion will be awesome. thanks.
Old Jan 27, 2010 | 08:11 AM
99SiStyle's Avatar
Default Re: b16a 1st gen
I used a gasket for a 99-00 Si B16A2, same gasket
Old Jan 27, 2010 | 10:26 AM
hurryup's Avatar
ok thanks.
Old Jan 28, 2010 | 09:06 PM
99SiStyle's Avatar
Just make sure you dont over torque it and crush the metal grommets.
Old Jan 29, 2010 | 08:14 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Crush the metal grommets? You will break the studs/bolts before you could ever crush those.
You can use any B-Series (B16 or B18) pan gasket... When you are getting parts you will be most likely more compatible with 90-92 Integra parts (cap and rotor, sensors, ect). If you need B16 specific like internal parts then use a Del Sol VTEC (1995 DOHC).
The reason for the Integra is if you need to replace oh let's say an injector, and you go with a 99-00' SI then it will now work without modification to your vehicle.
jchrm80
Apr 28, 2007 01:03 PM
B16CRXT
Oct 5, 2005 11:04 AM
Fatty_1775
Jul 24, 2004 04:40 PM
d0nkeyxPunch
Jun 8, 2002 03:08 PM
TurboSedan
Apr 4, 2002 07:41 PM
