WTB: FRONT AND REAR CAMBER KIT
I've got an ingalls style front camber kit you can have for free if you want to come to Green cove and pick it up. Why not just use longer bolts and washers for the rear? I believe every washer is about .5 degrees of camber.
You cant go wrong with FREE. How many washers and how long does the bolt need to be?
It depends on how bad off your rear camber is. I believe when I had mine I had 2-3 washers in there. The old Ingalls kits came with longer bolts and a handfull of wahsers. Bolts should only need to be about 1/4 longer if you are going with 3 washers or less. just put the washers between the controll arm and the body and that's pretty much it.
Found a link to it. fist is an Ingalls "kit" from summit.
Second is what I have for the front, but it's used and not red and fancy, oh and sorry but it's not JDM
Again, free if you want it.
http://cgi.ebay.com/ebaymotors/Ingal...Q5fAccessories
http://cgi.ebay.com/ebaymotors/88-89...Q5fAccessories
P.S. Laz, I think I need a larger pic of your Avatar please, thanks.
Again, free if you want it. http://cgi.ebay.com/ebaymotors/Ingal...Q5fAccessories
drewbie
13
Jan 6, 2005 03:13 PM
