EG hatch Orlando
Old Jan 27, 2010 | 04:52 AM
VTEC1n2nd's Avatar
Default EG hatch Orlando
Whats up guys?
For sale I have my EG hatch Shell It is a complete rolling shell. Comes with 2000 si FULL DISK BRAKES WITH itr BRAKE CALIPERS. EF si seats EG sir cluster 10k Hids Nrg QUick release set up with lock, ROta Group N's painted white vip[er alarm with two lcd remotes.Blox lower control arms (black) Skunk 2 lower tie bar. Brand new Tokico Bluie shock with coilovers in the rear. New 2000 SI OEM shock with lowering springs in the front. 2000 SI side skirts And brand new Innovative B series BILLET Mounts Never used. Minor sound system 10" Bazooka sub with amp and radio setup..AEM wide band and boost gauge. Im probably forgetting some other stuff. HAS A CRACKED WINDSHIELD.
For all that $2500 just need a swap and you're good.
I ALso have a Gsr block gaurded shortblock. Bored to 82 MM, along with 9:5 Compression CP piston Mildly used. Eagle rods, Arp head studs, ACT Maxx Extreme pressure plate along with a solid 6 puck unsprung ACT clutch. For this setup $1000 IT IS NOT ASSEMBLED. All machine work is already done, was a running motor tore down to do a refresh. IF you would like it to be professionally assembled. you can have it for $1220
IF YOU WANT IT ALL, $3000 BOTTOM DOLLAR.
Last but not least a COMPLETE SOHC turbo Kit...Only thing needed there is an Oil drain line. Has everytrhing. It is an EBAY setup, no shaft play. $350
Here are some pics of the car when it was together.. I will have to get some pics of the other stuff.
Old Jan 27, 2010 | 04:59 AM
VTEC1n2nd's Avatar
Default Re: EG hatch Orlando
THrow some offers. Thanks.
Old Jan 27, 2010 | 05:38 AM
nels00n's Avatar
bump for good body hatch shell but... 2.5 for a eg shell.....not in this condition
cryingsuns
Northern California (Sales)
10
Jun 8, 2013 06:48 PM
allmotorb18c14door
Mid-Atlantic (Sales)
May 4, 2011 06:07 PM
VtecLsEater
Mar 13, 2009 07:53 AM
Uniquerootz
Sep 20, 2006 11:12 PM
RedHB..D15B
Apr 5, 2005 07:51 AM
