F23a1 Engine with a Gsr Tranny.
Old Jan 26, 2010 | 10:12 PM
Andy_CG5's Avatar
Default F23a1 Engine with a Gsr Tranny.
I was told I could do a 5 speed swap with a gsr tranny on to my F23a1 engine but I was told I would need some kind of an adapter can anyone tell what that is? and Could someone give me a list of what I will need for this 5 speed swap.
Thank you.
Old Jan 26, 2010 | 10:42 PM
wolfy47's Avatar
Default Re: F23a1 Engine with a Gsr Tranny.
H to B adapter...are you putting a B tranny in a accord??? If you are please re-think what you are doing
Old Jan 26, 2010 | 11:15 PM
Andy_CG5's Avatar
H to B? the Trannys gonna be going on an F23.
Yea I wanna drive manual and I heard B series Trannys were good.
Old Jan 27, 2010 | 02:57 AM
davey5300's Avatar
I wouldn't do that if I were you.plus I hear them adapters are expensive. If anything I'd get an H22 tranny.
Old Jan 27, 2010 | 03:03 AM
hondamark35's Avatar
H-series and F-series share the same block design. because the H swaps are more common, everyone defaults to calling it H2B.
sure B-series transmissions are good if you have a chassis that came with a B-series (in one model or the other...) but this adapter plate that someone told you you could use is gonna run you more than an H22/23, F20B transmission with LSD..!
try looking for an H22/23 or F20B transmission. it'll have shorter gears than your F23 and should bolt right in without any adapters or modifications.
Old Jan 27, 2010 | 03:08 AM
i just checked.. $749 for the QSD kit w/o mounts, and over $900 for the Evolution Industries kit.
Old Jan 27, 2010 | 06:49 AM
Andy_CG5's Avatar
Oh dang Thanks for the help guys.
Can any of you help me come up with a list of parts that I would need for this swap.
Old Jan 27, 2010 | 07:29 AM
TouringAccord's Avatar
H-T Order of Merit
for which tranny? B series or H series?
if you are still thinking b series, here are a couple threads I found real fast that have already covered this...
https://honda-tech.com/forums/honda-accord-1990-2002-2/h2b-accord-2684753/
https://honda-tech.com/forums/honda-accord-1990-2002-2/b-tranny-f-block-2674646/
Old Jan 27, 2010 | 08:07 AM
361 accord's Avatar
dude, % gsr tranny would pulls sofaking dirty! but that motor doesnt like revving high forever like a 1.8
Old Jan 27, 2010 | 08:16 AM
nus_dogg's Avatar
Won't work on a Accord Chasis. Only in Tegs & Civics.
Old Jan 27, 2010 | 08:54 AM
Andy_CG5's Avatar
I found a seller that has an H22 Tranny but it comes with nothing but the tranny case. How much would that cost for just the H22 Tranny case?
Old Jan 27, 2010 | 11:51 AM
alkoholikwun's Avatar
just he case? forget that. look for a h23 tranny.
Old Jan 28, 2010 | 09:32 AM
Andy_CG5's Avatar
Heres what I'm gonna do now H22a4 head with f23a1 block and a 5 speed h22 tranny. How does that sound?
Old Jan 28, 2010 | 04:17 PM
BlkChryKord's Avatar
Are you actually doing it or just throwing out ideas from what you've seen/read?
Old Jan 28, 2010 | 11:30 PM
Andy_CG5's Avatar
I am planning on doing it once I get all the parts I have the H22a4 head already. Just need the tranny and a list of parts.
Old Nov 14, 2013 | 07:28 AM
g23cg5's Avatar
andy i am also doing to g23 Frankenstein motor with my f23 bottom end and h22 head
a few things to remember you have to convert to obd1 or you will have issues with the tunning but it can be done with obd2
also you will need a f23 and h22 water pump
press the gear from the h22 wp into the f23 housing
also the f23 bottom end has 6 oil ports wile the h22 head will have 8
plug 2 of them by treading some bolts into the ports and use a h23 head gasket
this may differ from head to bottom end
you will have to run your own water pipng also and the swap i have found says to use a b series trans but save your self h22 all the way but i am going to put a b20 crv trans with the transfer case and see if i can get awd out of it if any one has any idea on that one let me know
oh i almost for got you will also need a the h22 timing cog also the timming is the most important part of this swap !!!!!!!!!!
Old Nov 14, 2013 | 02:12 PM
apollo89's Avatar
If your tech savy take the h22 tranny with the f23 5 gear.
chicklet
Transmission & Drivetrain
Aug 20, 2016 10:19 PM
Street Ghost
Aug 14, 2003 10:40 PM
