what exactly do i need to run 550 injector? (did search)
try this post. hope it helps some. it has a wiring diagram. if you need more info try a archived search for resistor. https://honda-tech.com/zerothread?id=222366
To start off, you are going to need a good standalone to drive those injectors.
We have a diagram posted on the Hondata web site in the Tech section which should help.
Doug
Doug
oh i allready running 440s on a stage 4b........ thats right i forgot that you guys had a diagram on your site thanks
oh and how about the injector fitment like the clips, plugs, mounting, ect. anything i should know about those?
[Modified by 93B17A, 12:56 PM 9/5/2002]
Souldnt have too much of a problem. I had to take out the hard rings that go under the rubber orings in the intake manifold. The top cushions dont really do jack either but they fit in there well. They dont bind and have the little movement they need.
As for the wiring. Theres a harness that runs up on your drivers side shock tower, thats where you can mount the box and do the wiring.
b16a2coupe
Dec 10, 2006 06:17 PM
