Key has to be held to keep engine running?
Looking to buy a 1991 honda civic wagon that has 156k miles on it. One problem it has it that the key has to be held over to keep the car running. I was thinking maybe a iginition switch or something inside the column? The car is pretty cheap figured this might be and easy fix to get a 3rd car and let the coupe sit and get worked on. Any help would be highly apprechiated thanks.
hold it how so?
sounds like its probably an ignition switch problem though. test it!
http://mycomputerninja.com/~jon/IgnitionSwitch.html
Thanks for the responses, I'm going to go check out the car tomorrow probably. Other than the ignition it needs a new driver side window and its golden.
Erudito
Oct 27, 2012 07:28 AM
JScalf
Dec 24, 2010 08:20 PM
BlkGSR
Mar 7, 2004 06:28 AM
