Timing Belt / Water Pump? By Head or Block
HT White Ops
Ok, I'm prepping for my swap into my del Sol, and I need to know which water pump and timing belt to get.
The engine has a B16A3 head (del Sol VTEC) and transmission on a B16A2 (99-00 Si EM1) block.
For the 93-95 del Sol VTEC (B16A3), the water pump is:
WATER PUMP, KEIHIN
19200-P30-003
The matching belt is:
BELT, TIMING (UNITTA)
14400-PR3-004
For the 99-00 Civic Si (B16A2), the water pump is:
WATER PUMP, YAMADA
19200-P72-013
BELT, TIMING (124RU26 D-130) (UNITTA)
14400-P2T-004
So the question is, do I get matching belt and pump, or do I get the pump for the block and the belt for the head?
WATER PUMP, KEIHIN
19200-P30-003
14400-PR3-004
WATER PUMP, YAMADA
19200-P72-013
14400-P2T-004
how much of a difference is there in tooth count and length on the timing belt? get the pump for the appropriate block, but as for the belt, kinda depends on the difference in lenghts...shoot me a PM Eran if you dont have the appropriate info and i will look at the belts at my work tomorrow
njracer
Jan 10, 2008 05:07 PM
