Want to Buy Want to Trade/Want to Buy
Need TD44U Dist. EF SI CLUSTER
Old Jan 26, 2010 | 05:00 AM
EFjoe91's Avatar
Default Need TD44U Dist. EF SI CLUSTER
Looking to pruchase a Decent condition TD44u Dist. Purchased one off ebay and just seems to be bullshit.
Engine is throwing a code. Code 9 Cyl position sensor. That sensor is inside the dist. Cant fix, Brand new. Guy i got it from off ebay tells me its UNUSUAL to have a sensor go bad.
I simply told him that. How would I Know that there is even a sensor in there? and why would you have just said they never go bad. So its like fishing Got him hooked. Better yet Snagged. If i would have know it was a cheap dist i would have not went and got it. The end shaft had some play here is a pic of what i recieved. Note the endshaft play. Little loose looking. Was Reccomended something OEM ----> $ or Raybrig? from rywire.
Need a Civic EF cluster with tachometer. Either Si or SiR
Purchased one and it was from 4 door and does not work. Provided with the correct item i wont be buying things 2-3 times.
Old Jan 26, 2010 | 08:50 PM
Unsivil_audio's Avatar
Default Re: Need TD44U Dist. EF SI CLUSTER
I have an EF Si Cluster, make me an offer. I can pics of it if you'd like, but its in good condition.
Old Jan 26, 2010 | 09:00 PM
crx_si-r's Avatar
i have an Si and an SiR cluster. the Si one will need to have the center piece where the CEL, Seat belt, Door, etc replaced with your old one. make me an offer on that one. and the SiR cluster is mint condition with all pig tails. make me an offer on that one as well.
Old Jan 26, 2010 | 09:03 PM
crx_si-r's Avatar
i also have an oem obd1 TD68u will work with in place of a TD44U B16 distributor as well. its missing cap n rotor. or i can do cash + your old one i have a lifetime warranty and can possibly warranty out yours, get you a good working one and ship it back to you. lmk
nickelz34
10
Jul 20, 2012 07:11 AM
Uniquerootz
Oct 3, 2007 06:42 AM
Propulsion
Aug 11, 2004 12:48 PM
