rattling around shift lever?
I have an 08 Civic Si sedan and on rough roads a new rattling just started with the center console. It seems to abit loose on the side facing the passenger seat with the noise coming front the very front portion of the console. Any thoughts, it drives me crazy!
Solved the problem. I shaved a small peice of plastic off the front inside portion of the
center counsel. It appears the whole set-up had moved slightly towards the drivers side of the car and was rubbing.
i assume your some what of a mechanic, next time do not post?! unless its more threatning, just simply take it upon yourself and improvise a solution with what u have. i dont care if its an 88 crx or a 2011 civic, make it work.
$pecial K
Aug 14, 2002 10:46 AM
