z6 question
Old Jan 25, 2010 | 07:14 PM
vtecrasr's Avatar
Default z6 question
car is in time, has fuel, fuel relay is fine, ecu is fine, but no spark. replaced dizzy cap and rotor button, but dizzy gets power when you spin it over, but it wont crank. any help?
Old Jan 25, 2010 | 07:19 PM
egsleepercivic's Avatar
Default Re: z6 question
replace the coil
Old Jan 25, 2010 | 07:20 PM
vtecrasr's Avatar
already replaced
Old Jan 25, 2010 | 07:33 PM
mikej94civex's Avatar
sorry i got no info to help, but my buddy's z6 is doin the exact same thing! it was an auto made
5sp idk if that matters, but anyways if u figure out the problem please pm me and let me know, thanks!
Old Jan 25, 2010 | 07:46 PM
vtecrasr's Avatar
well here is the entire story. its a 97 del sol obd 2a to obd1 ecu conversion harness, chipped p06 ecu, d16y7 bottom end, vitara pistons, eagle rod,s cometic head gasket, hondata intake manifold gasket, greddy 15psi cast iron turbo kit, gsr throttle body, d16y8 intake manifold, rx7 460 cc saturated injectors, 255lph fuel pump, d16z6 head, titanium valves, arp head studs and rod bolts. it is running a d16y8 engine harness with a rywire obd2 to obd1 distributor adapter. took the coil cap and rotor button from the y8 distributor and put it into the z6 dizzy. and still doesn't get fire
OTiS515
Oct 7, 2009 05:42 PM
jewpont
10
Oct 12, 2008 03:49 PM
Sir_LagaLot
12
Dec 29, 2005 12:56 PM
olsupra
Jun 7, 2004 08:52 PM
bambam
Nov 20, 2003 04:20 PM
