Pics of my 1985 CRX SI Autocrosser (E-Prepared)
Look, but don't touch
Teaser:
http://www.rickshank.com/gallery/
Let me know what you guys think.
Mods to my car:
original 1.5 SOHC 12 valve 5 speed- rebuilt with total seal rings and
bearings, OEM Honda parts, 3 angle valve job, machined head, deck, and
cylinder walls. Mobil1.
85 SI Tranny, OPM Motorsports LSD, Redline MTL
Lightspeed thermo wrapped air intake with heat shield K&N cone filter
DC sports ceramic coated 4-2-1 header
Gude performance 3131 .412 lift/.232 duration camshaft
AEM adjustable cam gear
MSD 6AL ignition with adjustable rev limiter control module
MSD Blaster SS E core 48K volt coil
BWC silicone plug wires with NGK V resistor plugs
87 Acura Integra D16A1 fuel injectors and engine computer
Unorthodox Ultra R 12 ounce aluminum race crank pulley with no accesories except alternator
Homemade exhaust setup, 2.5", (2) dynomax bullet race mufflers, with a turndown , under the car
Pacesetter short throw shifter
Lightspeed torsion bars with Tokico Illumina shocks up front
Ground Control coilover sleeves with Eibach 450 lb. race springs on KYB gas
shocks in back
Energy Suspension entire car polyurethane suspension bushing kit
Stock brake rotors and calipers with AEM brake pads
Autometer 5" tach, shift lite, vac, volt, air/fuel, and water temp guage
panel - reworking this setup, as the dash is coming back out again, and i'll probably swap the vac gauge for a fuel level gauge
Gutted interior, lexan sunroof, no rear wing
13"x7" Revolution RFX wheels, wrapped in Goodyear 20.0"x9.5"x13" Cantilevered slicks.
Weights 1630lbs sans driver.
Cya!
~ricky shank
Teaser:
Mods to my car:
shocks in back
Cya!
~ricky shank
good work on ur car
not a lot of those around with that setup.. congrats and keep it up!
288,xxx miles on the ticker of that thing.Actually, in my area, 1st gen CRXs and 3rd gen civics (84-87) are quite popular, as Mr HondaGuru, Mike Ancas www.speednation.com is from the Pittsburgh area. Great tuning advice from him is always welcome
~ricky shank
the "check out my car, what do you think of it?" posts are restricted to the "pictures of your vehicle...." thread which is at the top of the thread list. as soon as a mod gets to it your thread will be locked.
oh yeah, in before lock.
Sorry, but this doesn't appear to be the routine:
"Look at my car's asthetics..."
This is a racecar that IMO could inspre some nice technical discussions.
I think it's a tad extreme to lock a thread just because it has a picture in it.
Ground Control coilover sleeves with Eibach 450 lb. race springs on KYB gas shocks in back
after noticing the spring rate, i was wondering if you have had any problems with the kyb shocks. i know the agxs have a hard time handling those types of spring rates...
~ricky shank
as for shocks, i'd recommend getting Koni yellows and for other suspension goodies, check out http://www.opmmotorsports.com..
The Illuminas aren't too bad I just slapped on up front. I've got Koni single adjustables on my 89 Civic SI, and I love em. $$$ though.I'm already considering OPM's rear adjustable swaybar.
This winter I've got a source for a few sets of OPM look-alike camber plates from aluminum if there is interest.
~ricky shank
also, AEM brake pads???? are they even good? i'm running hawk HP+ pads which work great for my car... (weekend auto-xer)
My brakes get quite warm after an auto-x, but never any fade (DOT 5 fluid, regularly flushed since it's synthetic)
AEM pads are made by Nissin. (not Nissan).
~ricky shank
~ricky shank
as for shocks, i'd recommend getting Koni yellows and for other suspension goodies, check out http://www.opmmotorsports.com..their prices arent that good ****
~ricky shank
their prices for konis are horrid i was like good damn yellows arent that expensive but when u look there its looks like they are charging u for 2??
ZEX Man
Dec 2, 2004 02:02 PM
MiXeD Up CiViC
Oct 22, 2003 08:35 PM
