Common reason for this...
Usually I would not post in this forum but this involves a 92 EG8 M/T. I need a common reason why the check engine light would come after the car is warmed up, no consistency though. Goes off when the car is turned off. Read in the search achieve that a bad ecu might cause this? Any input is appreciated.
oxygen sensor needs replacing thats what happened to mine and it was that if thats not it then use a paper clip to short the ecu to spit out the code by flshing the check engine light idk exactly where you stick the paper clip but u can just look it up somewhere
ramz7887
Nov 13, 2007 03:07 PM
ph0shizzle
May 13, 2006 08:36 PM
crxaddikt
Dec 1, 2003 09:23 AM
BigMig
May 10, 2003 06:01 PM
type Gendy
Apr 21, 2003 04:48 PM
