Accord Coupe 2000 - OEM Brake Pads
I am looking to replace my brake pads on my 2000 Accord Coupe. I am happy with the OEM brakes and was looking to buy them online and was wondering if anyone knew what the part number is for the front and rear brake pads or who makes the OEM brakes. I have found some at http://www.thepartsbin.com and I am not sure which model is really the Honda Part.
Thanks!
Thanks!
If yor car has a V6, the fronts are 45022-S87-A01, the rears are 43022-SY8-A01.
If you car is 4 cyl, the fronts are 45022-SY8-A01, the rears are 43022-SV4-622.
I recommend using Genuine Honda Pads or AKE Bono. Hope this Helps.
Thanks!
Thanks!
the 4 cyl fronts are 45022-S84-A01, and the v6/4cyl rears are interchangable (43022-SV4-G22 for V6, or 43022-SY8-A01 for 4 cyl).
I belive factory is Nissin, but Akebono is good also. Another not bad factory replacement with a slight performance gain is Metal Master (Axxis or PBR).
kapowser
Oct 31, 2008 06:55 AM
2000, 43022sv4g22, 43022sy8a01, 45022s84a01, 45022s87a01, accord, brake, brakes, break, honda, number, oem, pads, part, pbr
