INT radiator into EG
Old Sep 5, 2002 | 02:26 AM
D16Z6racing's Avatar
Default INT radiator into EG
Ok, I only know of cutting the existing mount, having it moved, then rewelded. I heard there is a mount kit out there for this radiator swap. Anyone know? If so how much. This place wants $60 bucks to do the cut/weld/install. Good price?
Old Sep 5, 2002 | 02:50 AM
Honda4CX-T's Avatar
Default Re: INT radiator into EG (B18CX-EH)
Never heard of a kit. I had my local "trusty" shop cut the mounts off for the A/C Condenser and weld up the other lower rad. core mount in place.
Shop did it for $45.00 to remove and weld mount. They also cut and flip the hood latch cross memeber section to make Integra Condenser fit inside as well.
So $60.00 is not to bad.
Old Sep 5, 2002 | 06:05 AM
Default Re: INT radiator into EG (Honda4CX-R)
I'm gonna have to offer $50. The work is hella easy, I just don't own the equipment to do it. We're talkin' about 20-40 minutes here. That includes draining and filling the radiator too.
Old Sep 5, 2002 | 07:22 AM
bikeboy80's Avatar
Default Re: INT radiator into EG (buster13)
its not hard at all, cut out all four tabs, with a dremel or whatever, and then i used two pieces of thick alum to make two brackets to hold the bottom of the rad, if you look under the car at the splash shield there are two threaded holes that you can use to attatch the brackets, and then the same thing for the top, just make up a few brackets, actually i modified the integra top brackets to work, thats it
Old Sep 6, 2002 | 05:24 PM
hatchy's Avatar
Default Re: INT radiator into EG (bikeboy80)
That is almost exactly what I did. I used an angle grinder to cut off all the support mounts (5 minutes) and made brackets for the ITR radiator and it fits very nicely. Go to hybridforum.com, there is a nice article on how to do this, with pictures and all.
Old Sep 6, 2002 | 08:23 PM
gsrvx's Avatar
New User
http://tech.hybridgarage.com/tech/jsrad/jsrad.html
codyellis
Mar 14, 2010 12:06 AM
EFstyle
Nov 12, 2008 09:43 PM
CasperX
Dec 18, 2007 02:34 PM
whole9
Mar 31, 2007 03:23 AM
xci_ed6
Welding / Fabrication
Dec 28, 2004 05:10 PM
