gx pistons specs.
Old Jan 24, 2010 | 05:20 PM
j0keefe21's Avatar
Default gx pistons specs.
been looking to possibly do a gx piston/ ls rod combo but im having trouble finding consistant specs. i hear people using the same combo getting a high 11 to 1 cr. if i use zealautowerks specs i get a low 12 to 1 cr. and some specs i find when i put it in a calc will get me a high 12 to 1 cr. which is too high. just seeing if anyone knows for sure what the specs are on the pdna00 pistons. thanks
Old Jan 25, 2010 | 07:58 AM
kingofbattle909's Avatar
Default Re: gx pistons specs.
ZEALAUTOWERKS.COM
Old Jan 25, 2010 | 09:31 AM
Jimster480's Avatar
zealautowerks is pretty close on compression ratios for alot of the D series stuff. I think its correct to say that it will be 12 compression, because the GX has over 12:1 CR.
D16B5
(Identical to the D16Y5. Main differences are Pistons, Rods, Camshaft, Head Gasket, Intake Manifold, and Exhaust Manifold are PDN rather than P2M)
* Found in:
o 1998-2000 Honda Civic GX
+ Displacement : 1,590 cc (97 cu in)
+ Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
+ Rod Length : 137 mm
+ Compression : 12.5:1
+ Combustion Chamber Volume : 32.8 cc per cylinder
+ Power : ? hp (? kW, ? ps) @ ? rpm
+ Torque : ? ft·lbf (? kg/m, ? Nm) @ ? rpm
+ Valvetrain : SOHC VTEC-E
+ VTEC Switchover : 5700 rpm
+ Fuel Control : OBD-2 MPFI
+ ECU Code: PDN-A02
Old Jan 26, 2010 | 07:34 AM
j0keefe21's Avatar
ok thats good because i use zeal autowerks for alot of stuff. other question is how much whp could i put down with those pistons and ls rods? i mean tuned properly. ive heard 300whp on rods but nothing about pistons thanks
Old Jan 26, 2010 | 11:52 AM
Jimster480's Avatar
it depends on your setup. 300WHP would be the limit for the rods.
Old Jan 26, 2010 | 07:38 PM
j0keefe21's Avatar
its going to be a staight d16 12.1 cr. zex stage 2 nitrous cam. bolt ons, nitrous and meth. i just want to know what the pistons can handle
Old Jan 26, 2010 | 07:54 PM
Jimster480's Avatar
would depend on your timing. They might be able to handle 300HP. You should probably get them treated with ceramic coating or something if your going on alot of spray.
Old Jan 26, 2010 | 08:03 PM
j0keefe21's Avatar
yea ive looked into coatings and probably will go with one and do it myself. the pistons should be in next week and im in no rush to just throw it together and have it not run right. got any suggestions on a coating? i plan on 100shot or more depending on my egt's and other things
Old Jan 26, 2010 | 08:27 PM
Jimster480's Avatar
i know bisimoto offers ceramic coating, and thats the only coating that he offered. So thats what i would recommend. I read about ceramic coatings, and they are supposed to be very good for nitrous setups.
Old Jan 26, 2010 | 08:45 PM
Aquafina's Avatar
Coating doesn't make them any stronger...
Old Jan 26, 2010 | 09:02 PM
Jimster480's Avatar
not physically stronger, but more resistant to heat/warping/melting.
Old Jan 27, 2010 | 08:24 AM
j0keefe21's Avatar
alright ill check them out and do some research. i know they just add a thermal barrier and dont make them physically stronger but as far as nitrous goes ur mainly concerned about melting ne ways.
Old Jan 27, 2010 | 08:34 AM
BearsEK-KMSU's Avatar
The ring land thickness and what material the piston is made of is most important.
Old Jan 27, 2010 | 08:36 AM
Jimster480's Avatar
and how good the cast/forging is. Look at Vitara pistons, they are just aluminum cast pistons and they hold 400+ HP. The current record on them is 634WHP.
Old Jan 27, 2010 | 08:44 AM
j0keefe21's Avatar
haha well this all goes back to the orginal question how good is it and how much could it hold reliably.
seigisama
Engine Machining & Assembly
Aug 5, 2016 03:47 AM
devious_yeti
May 2, 2016 07:30 PM
dynodon63
Oct 12, 2015 05:14 PM
fjt
Jun 9, 2010 06:18 AM
