OBD1 Fuel Injectors
So heres the situation. I'm trying to get my emissions done but i'm throwing a CEL for code P0172 for the fuel system running to rich. Anyways we are trying to diagnose the problem as we believe my fuel pressure is fine.
We believe the problem is with my fuel injectors as I tried a different setup when I took the supercharger off my Type R. I had DSM 450cc's in it when it was supercharged so instead of rewiring it back to my stock Injectors and found some N/A DSM 240cc's and thru those in. We believe they may be the cause of my CEL and also found 2 of the injectors nozzels are cracked.
Now onto my question. I no longer have my original stock OBD2 240cc Injectors. I do however have a set of OBD1 240cc Injectors and clips that I could wire in in place of the DSM's that are in there now.
Will my car be fine with Running these OBD1 injectors. From what I understand is it should run exactly as the OBD2 Injectors would assuming the clips are wired correctly as the only difference between the OBD1 and OBD2 injectors are clips on the injectors themselves.
Anyways I just wanted to verify if this is correct before I wire them in and they dont' work right then have to redo it for OBD2. Please help me out with this as I have to get the car to pass emissions by the end of the month.
