how do u change a distributor?????????
Old Sep 5, 2002 | 12:26 AM
ochdog's Avatar
Default how do u change a distributor?????????
hey whats up fellas i just found out my distrubutor bearing busted loose or some **** like that but i need to get a new distributor and i was wondering if u guys can point me in the right direction on how to change a distributor on a 92 honda civic si ......well thanks in advanced
[Modified by ochdog, 9:26 AM 9/5/2002]
Old Sep 5, 2002 | 03:50 AM
hondafrk's Avatar
Default Re: how do u change a distributor????????? (ochdog)
very very simple. You can first unbolt your distributor cap, There are three bolts you will have to remove to do this, Then you will have to get a little pick or a very small screwdriver and remove the two electrical connectors on the back side of the dist. Then once you have them disconnected you will need a 12mm socket a 4-6" extention and you will remove the three bolts holding the dist to the head. But before you pull the distributor off make sure you use a sharpie marker or something to mark the location of the dist on the head, Then once you have done this carfully pull the dist off the head. Then find a little rag or something and stick it in the hole so oil wont get all over the place. It will only be a little oil but if your as **** as I am about a clean engine you will have to do this.
CBR
Dec 22, 2014 04:52 PM
ribal_gh
11
Sep 27, 2012 01:08 PM
polyhonda
Sep 5, 2008 01:50 PM
RA61825
Mar 12, 2006 02:26 PM
davekaro
Apr 7, 2004 06:20 AM
