Different timing belts
Old Jan 24, 2010 | 07:10 AM
Shawn_71288's Avatar
Default Different timing belts
Is there any difference between the y8 timing belt and the z6?? I have an 89 si with a z6 bottom end and a y8 topend. I was told to use the y8 timing belt, I work at Oreilly auto and the belts r the same part numbers. So can someone give me a tooth count for both belts please.
Old Jan 24, 2010 | 07:34 AM
90 si's Avatar
New User
Default Re: Different timing belts
if they both have the same part numbers and you work there then why dont you just count the teeth
Old Jan 24, 2010 | 05:18 PM
It's the same part number which means it's the same amount of teeth 104 but I was told to use the y8 timing gear and the y8 belt on my motor which is a z6 bottom y8 top but there is no difference in the aftermarket part. So as I was askin is there a different y8 belt that is not in the aftermarket auto parts world
Old Jan 24, 2010 | 05:20 PM
And if so how many teeth. I've already talked to aem about the camgear they r the same 38 teeth for both the z6 and the y8 motors
THEDirtyDseriesWOOT
Sep 19, 2006 03:37 PM
FS_WTB
Mar 9, 2006 12:49 PM
19civiclx95
Dec 27, 2005 08:23 PM
