putting the clutch the wrong way.
i have a question for those whose got more experience out there.
what would happened if you put the clutch the wrong way...
http://www.hondaautomotiveparts.com/...RQUE+CONVERTER
from that picture, #4 is the clutch, imagine it flipped the other way around where the clutch springs and the outlet is facing the other way towards the flywheel rather than the pressure plate.
what would be the defectiveness with this setup?
car wont go anywhere?
clutch wont grab? etc etc?
any help would gladly be appreciated! thanks!
you wouldn't even be able to bolt the pressure plate to the flywheel, considering the side with the springs would be pressed right against the flywheel and the pressure plate couldn't get to the flywheel......
You can get the clutch disc backwards on some vehicles, but not on a honda.
methanemotorworks
Feb 13, 2006 07:32 PM
vtec.dc2
Oct 13, 2002 06:07 AM
