car dies at idle with cams
Old Jan 23, 2010 | 07:30 PM
JDM_Certified's Avatar
Default car dies at idle with cams
its a 91 ef hatch with a b18b motor...and car is running obd2 right now...and we installed cams..don't know the duration but the intake lift is 214 and exhaust lift is 228...if motor is cold, car will die automaticly..gotta rev the motor at 1k for about a min or less for it to idle and not die..whats wrong with this? or is there anything i did wrong?
Old Jan 23, 2010 | 08:08 PM
Eighty-Nyne's Avatar
Default Re: car dies at idle with cams
lmao, if that's the lift it's 2/5ths less lift than stock cam specs.
if it's the duration it's a few degrees less than stock cam specs.
So what you did wrong was you installed unidentified cams. So you have no idea what they are designed to be degreed to.
And when you install large cams, of course it won't idle unless you bump idle and tune.
Old Jan 23, 2010 | 08:10 PM
.Manny.'s Avatar
Touching My Member
Good job.
Old Jan 23, 2010 | 10:04 PM
D16SiHatch's Avatar
holy facepalm
Old Jan 24, 2010 | 01:54 AM
Danthemagicbum's Avatar
You need a new motor now.
No, you need a tune.
Old Jan 24, 2010 | 07:06 AM
89s1's Avatar
Originally Posted by Danthemagicbum
Look at me trying to be funny and fit it.
All the posts above that one pretty much cover it.
Old Jan 24, 2010 | 07:25 AM
Nobody told him how to fix it, Eighty-Nyne said "
And when you install large cams, of course it won't idle unless you bump idle and tune." but that didn't explain how to fix it. I am assuming OP doesn't tune cars because if he did he would have know what he did wrong.
Old Jan 24, 2010 | 02:51 PM
yeah i know..man enough to admit my faults...i don't know how and still learing..searched and couldn't find anything..i tried to adjust the sprockets and all..but still didnt' work..and the cams aren't smaller than the stock...cause i compared it...and it was bigger..if i remeber correctly with was the stage 2 crane cams...so how do i fix this...
Old Jan 24, 2010 | 03:27 PM
Buy adjustable cam gears->take it to a tuner.
Old Jan 25, 2010 | 01:29 PM
here's the cam specs...advertised duration is intake/228 exh/246....and he's cam settings is, exh. advance 3 intake is advance 2 degrees...isn't it suppose to be the other way around...retard on the exhaust and advance on the intake cam...if we had a dyno from where im from then i would take it..but we got no access to any dynos...so how can i set this?
Old Jan 25, 2010 | 05:02 PM
D16SiHatch's Avatar
this is probably something you should have looked into before installing those cams then. they are not just install and go. you need a tuner and a dyno to make them work properly. it's not as simple as just advancing or retarding the cams. you better find someone who can chip/tune hondas, otherwise those cams are most likely coming back out.
Old Jan 25, 2010 | 05:32 PM
grog's Avatar
Very true,
OP i suggest you go online or make some phone calls, try to find a "tuner" near by,
You'll probably have to drive somewhere.
Where are you anyway? maybe we can help you find a "tuner".
Old Jan 25, 2010 | 06:02 PM
88crxjordan's Avatar
turn the idle up a little rite?
haulinhonda
Mar 11, 2013 02:11 AM
egsi32
13
Jun 22, 2005 10:30 PM
Crisgo
Apr 7, 2004 08:06 AM
TEGPOWER44
Jan 26, 2003 11:48 AM
HX_Guy
Jun 13, 2002 09:52 AM
