Rear disc w/o swapping suspension?
Old Jan 23, 2010 | 07:10 PM
terror_storm's Avatar
Default Rear disc w/o swapping suspension?
I've been searching and reading but can't find a clear answer on some questions I have.
1) Can I just use the caliper brackets (and calipers, pads, etc.) from a CRX to put discs on the rear of my '90 HB (See the first picture)? Will it bolt to the trailing arms on my car?
2) Is the caliper bracket removable from the trailing arm of a '90-'93 Integra? It doesn't look like it from the manual (See the second picture).
3) Also, I saw on the Super Street website that they simply bolted a bracket to the trailing arm to use some aftermarket setup (See third picture). Has anyone done this with factory calipers and brackets?
Basically I'm looking for an alternative to swapping the trailing arms.
Thanks!
CRX:
Integra:
Super Street (http://www.superstreetonline.com/tec...des/index.html)
Old Jan 23, 2010 | 09:04 PM
grog's Avatar
Default Re: Rear disc w/o swapping suspension?
I've heard this is possible, but i've never seen it. I have both crx/civic and integra trailing arms in my garage. they're both bolted to the trailing arm with star bits.
Yeah the crx and da rear calipers and pads are the same, and the caliper bracket should fit too.
You should make certain you can for sure remove those bolts alright, the integra trailing arms that I have are extremely rusted on the caliper bracket,(so rusty i decided not to use them) which is removable on the DA btw.
Old Jan 24, 2010 | 06:29 AM
uberEFtuner's Avatar
Just do the full swap. You will need to swap out the bushings anyway. And where are you going to get that bracket?
Old Jan 24, 2010 | 06:34 AM
I am looking into getting a bracket made. I've got a rough design, just need to take some measurements and check to see if a flat plate will do the job.
Old Jan 24, 2010 | 06:41 AM
beansandrice's Avatar
If he knows about the install then I am pretty sure he knows about the bracket+kit and all associated hardware. Now i think this is a good thread because it touches basis that I have also been pondering. Like
are disc brakes even needed on a 2100 pound car? Most people want them for looks now a days. Back to the OP's Q. I was always under the impression that you need the complete trailing arm to do the swap (aside from the correct prop valve) but now you have me thinking also. And yes most of our (old cars) have those insanely rusted star bits that are a bitch to remove when they are in good shape. I guess you can grind the heads off and remove the studs but... Keep this thread going.
Old Jan 24, 2010 | 06:51 AM
I don't necessarily want them for performance, and I definitely don't want them for looks. I hate drum brakes. I would much prefer to have discs on any car.
The only reason (the way I understand it) to swap the arms is to get a mount for the caliper. But then you can possibly run into alignment issues if you use the wrong parts. My friend had a EF that they used the wrong compensator arms and it drove like ****. Now I know that's a pretty basic mix up, but I would rather avoid all of that and just keep the parts that are on my car now.
IMO I would rather have to drill out or cut off 4 bolts than swap the entire rear suspension.
vonlefty's Avatar
You should be able to switch the spindle from the disc trailing arms onto your stock trailing arms by removing the spindle nut and the 4 star bit bolts. You'll still need the correct hoses and brake cables.
Old Jan 26, 2010 | 08:31 PM
freon480crx90's Avatar
you can def do this. i did. i mounted DA spindles on my dx trailing arms.
Old Jan 26, 2010 | 09:04 PM
elf469's Avatar
isn't that what fastbrakes.com does with thier drum to disc conversion?
Old Feb 8, 2010 | 07:26 PM
Okay well I got it all figured out. I'm waiting on bids to have the plates CNC'd. Is anybody interested in this?
Old Feb 9, 2010 | 04:37 AM
sepetinswenze's Avatar
I am interested, but i live in Australia... unless your willing to post em here..??
Old Feb 9, 2010 | 06:17 AM
I have no problem shipping.
Old Feb 9, 2010 | 06:41 AM
lif3tak3n's Avatar
Shoot I'm definatley getting disc for the looks I don't care they look better and ALSO have better performance. whether my car was 2100 or 1100 I think they look good and have better heat displacement :thumbsup:
BTW I got a CRX Si rear disc conversion (I also got the CRX Si Fronts) so it might be what your lookin for
Old Feb 9, 2010 | 06:49 AM
Just wondering what the plan is? You need different ebrake cables for the rear disc setup. Where are you going to get those?
Old Feb 9, 2010 | 07:24 AM
I want to try to make an adapter to use the drum brake cables. But if that doesn't pan out, I have found them new for around $80 or less for a pair.
Old Feb 9, 2010 | 07:51 AM
lif3tak3n's Avatar
Dude ! Auto Salvage $10
Old Feb 9, 2010 | 07:58 AM
The only Integra I have found locally was rusted/seized.
Old Feb 9, 2010 | 08:17 AM
4drEF's Avatar
Keyboard Humorist
That's the way most of them are.
The screws are really not easy to get out so it's far easier to just swap trailing arms.
Old May 27, 2010 | 10:58 AM
I've seen this picture a few different places on the 'net:
The spindle on the right is what my 1990 hatchback had. The one on the left has a different bolt pattern, and there are other possible differences as well.
However, I think that if you measure the distances between the bolts, you can tell which one you have. See the picture below:
Old May 27, 2010 | 01:58 PM
Hey terror storm. To avoid confusion and get more participants for the rear disk bracket we should stop using this thread and focus more on your other.
Old May 27, 2010 | 05:33 PM
shocker911's Avatar
id DEF. be down for the bracket. LMK id pay for it
Old May 27, 2010 | 07:33 PM
EE2bitsk's Avatar
just a question... why wouldnt you guys just get the whole DA/DC set-up instead?
jaypain
15
Dec 12, 2008 02:23 PM
SpoogenJay
May 8, 2007 10:42 AM
Phyreangel
11
Nov 23, 2006 07:46 PM
damn_import_culture
Jan 1, 2005 01:07 AM
