did my timing belt today. having an issue with idle
Old Jan 23, 2010 | 02:13 PM
tougetuned_ef's Avatar
Default did my timing belt today. having an issue with idle
ok so today i did my timing belt and waterpump on my 1st gen crv. ive done motor swaps but never did a timing belt before.
i went to the dealer to get the 50mm crank pully tool and to talk to my buddy who is a tech there and he lent me a service manual for my crv. i followed all the steps in the book and i even turned the crank and cams to make sure no valves were hitting any pistons.
when i first started it when i was done i noticed it running a little rough. i tried adjusting the dizzy a little bit to see if that helped and nothing. its just barely rough but its enough that i notice it. i do alot of long distance driving and im about to drive to vt next month so this needs to be fixed, and i have this crank pully tool on rent from the dealer till monday.
Old Jan 23, 2010 | 02:21 PM
sik96teg's Avatar
Default Re: did my timing belt today. having an issue with idle
your probably off a tooth. you can be off a tooth and not bend valves. what motor do you have in your crv.
Old Jan 23, 2010 | 02:33 PM
soon2bdropped's Avatar
mostly like off a tooth.
Old Jan 23, 2010 | 02:47 PM
b20z it looked like the marks on the cams wernt perfectly the same direction. i tried to turn the exhaust cam to be even with the intake but the valve springs were holding it too tight. i guess i have to take it all apart then.
Old Jan 24, 2010 | 08:32 AM
ok so today i woke up and took the car back apart again and fixed the cam. it was def off a tooth but now it runs perfect. but now my powersteering is all f**ked up! at first it was skipping and chattering so i adjusted the tension on it and its just not working at all. could i have gotten air into it by just lifting it up and laying it on the intake?
Old Jan 24, 2010 | 10:18 AM
i went and got a new belt and it fixed the problem
f20beme
Apr 13, 2015 04:34 AM
Ef4doorwagon
17
Aug 30, 2014 11:58 PM
turboedsupe
Sep 19, 2008 04:32 PM
98-ls
Mar 19, 2004 06:22 PM
P1mpSlap
Jan 7, 2004 10:50 PM
