Spark,fuel,and compression wont start after MPFI Con.
Old Jan 23, 2010 | 12:19 PM
coreysef's Avatar
Default Spark,fuel,and compression wont start after MPFI Con.
Well I have a 1990 ED civic hatch I had circuit overload before but I fixed it.Now I only have one code and that is 6 which is ECT engine coolant temp.But I have spark and I have fuel but car wont start.I also have skunk2 mani so all vac. hoses are blocked off map sensor on tb.I ran four wires to ecu which was for TDS and CPS.But car still wont start timing is also correct so Im stomped help please. Did multiport using angel fire intructions.
http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
Old Jan 23, 2010 | 05:52 PM
slowef71's Avatar
Default Re: Spark,fuel,and compression wont start after MPFI Con.
i had the same problem .. it timing.. adjust the dizzy
Old Jan 23, 2010 | 06:33 PM
Targa250R's Avatar
be professional
A faulty or missing TW sensor (a.k.a. ECT sensor) can cause hard starting or a no-start condition due to grossly improper air:fuel mixture. You should look further into that problem.
Old Jan 23, 2010 | 06:42 PM
coreysef's Avatar
tried that still didnt work I advanced it a little and it didnt help the motor has some aggresive cams but I dont think that would affect anything.
How would it cause improper air fuel mixture?And on my harness I dont see a plug for it my harness came from a dpfi 1990 ef.
Old Jan 23, 2010 | 07:34 PM
Targa250R's Avatar
be professional
What is this about "aggressive cam"? Did you just install this now or did the engine run with it previously?
Have you ever operated a lawnmower or other small carbureted engine? What do you have to do on a cold start-up? Think about it.
The harness should have a plug for it. If it doesn't, then you should get another harness. All fuel-injected Hondas have a TW/ECT sensor.
The sensor is screwed into the cylinder head directly under the distributor. It has a 2 pins and a round black or white plastic shroud.
Old Jan 24, 2010 | 04:43 AM
coreysef's Avatar
I have ect sensor one on the head and one on thermostat housing its plugged up to one on the head.And motor was rebuilt everything new except cams.And on smalll engines usually have to be primed. I did that already by unplugging dizzy.Wonder if missing vacuum lines is cause.
Old Jan 25, 2010 | 08:10 AM
coreysef's Avatar
TTT
91DA buffalo
Aug 2, 2011 12:06 PM
hatche1
12
Apr 21, 2011 11:03 PM
corince06
Nov 17, 2008 08:28 AM
jdmallmotorhatch
Aug 15, 2008 11:03 PM
stocker2shocker91
Dec 20, 2006 05:24 PM
