engine niose and viberation after timing belt chenge
Old Jan 23, 2010 | 07:05 AM
k2p2's Avatar
New User
Default engine noise and viberation after timing belt chenge
I just changed my water pump and timing belt.
Everything was aligned ( took it apart twice). Now the car runs perfectly however right around 3500 RPM before it changes gears the engine vibrates causes a noise. The noise is felt inside the car ( The dash starts vibrating).
Can anyone tell me what could be wrong ?
Could an improperly put in motor mount cause the symptoms ?
The car is a 99 2.3 f door accord
Old Jan 28, 2010 | 09:00 AM
hondamark35's Avatar
Default Re: engine niose and viberation after timing belt chenge
just some suggestions; check motor mounts for torn rubber or loose fasteners, confirm timing of balance shaft components, check accessory belts.
Old Feb 1, 2010 | 07:29 PM
NoLeftTurn's Avatar
Is the oil pump and balancer shaft aligned? You can check by putting it on TDC and pulling the bolt above the axel and put a pin through it. Thats how you check the oil pump. And the balancer shaft should also have a mark on it also.
Old Feb 1, 2010 | 08:15 PM
zimmy709's Avatar
be sure you reinstalled the 4.5x11mm key in the keyway on the on the crankshaft, this keeps the crank pulley turning with the crank... also be sure your crank pulley bolt is tight.
His_Dudeness
Sep 18, 2010 11:45 AM
SlammedDC2teg
Aug 19, 2010 10:16 PM
truckdude239
Nov 19, 2009 09:18 AM
H - Badge Boondocker
Mar 2, 2009 05:27 AM
thechamp657
Oct 6, 2007 12:18 PM
