ZC oxygen sensor; will Si work?
Old Sep 4, 2002 | 09:58 PM
gregv's Avatar
Default ZC oxygen sensor; will Si work?
hey guys
my ZC came with a broken oxygen sensor on the exhaust manifold; since these are about $250 CAN$,
I was hoping the one off my '91 Si would work, even though it looks different. Can anybody confirm this?
Also, how the hell do you get these things off? Is a special tool required?
thanks
greg v
Old Sep 5, 2002 | 04:13 AM
89civicdx's Avatar
Default Re: ZC oxygen sensor; will Si work? (gregv)
yes the si will work
use a 22mm wrench
Old Sep 5, 2002 | 06:50 AM
USDM 4G VTEC's Avatar
yes as long u use a single wire O2 sensor it should work........
and be careful when taking them out...... they tend to peel easy....since metal contracts easy and stuff with heat.. do this..... turn the engine on for 2 minutes, then turn off..... that little heat will help u take it off a little easier, and be careful not to burn urself.... when u install the new one in, make sur eu put anti-seize in the tread...
~sp33~
10
Mar 3, 2008 02:28 PM
-[sphEre]-
13
Oct 14, 2004 08:08 PM
R6Boy69
Aug 22, 2001 08:48 AM
