D16Z6 swap ECU question Help
Old Jan 22, 2010 | 12:50 PM
low-1's Avatar
Default D16Z6 swap ECU question Help
I'm trying to finish my D16Z6 swap and the ECU that came with the motor is a 37820-PT3-A04 which i looked up on hondata and its to a 92 accord OBD1 im not sure but will this work or am i on the ECU search again?
Old Jan 22, 2010 | 12:58 PM
lunalink's Avatar
Default Re: D16Z6 swap ECU question Help
if you're putting it in ur EF you need to buy a obd0-obd1 jumper harness and use that ECU. if its for that motor i dont see why it shouldnt work. post pics and more detailed information so fellow members can help you.
Old Jan 22, 2010 | 01:04 PM
low-1's Avatar
info: 90 crx d16z6 swap trying to finish up wiring and ecu swap to get vtec hooked up i have the correct dist. but i think the guy gave me the wrong ECU not sure its for a F22 Accord. I'll get some pics up soon
Old Jan 23, 2010 | 12:30 PM
sanimalp's Avatar
$cat /dev/urandom
that is absolutely the wrong ECU. a z6 should have a p28 ECU. You can use a host of other ECUs from the obd1 set to run that engine, like a p06 or p08, but the pt3 is not in that set.
no need for pictures.. you should talk to xenocron and see if you could send him in a pt3 and buy a p28 or equivalent from him.
CRX-Kid11
Oct 3, 2011 04:34 AM
1sickeg8
Dec 4, 2009 10:07 AM
sc95delsol
Oct 16, 2007 05:23 PM
TehMoonRulz
Apr 4, 2005 06:38 PM
B_1_8_hatch
Jul 30, 2002 07:06 AM
