shift linkage on a cable tranny?
Old Jan 22, 2010 | 08:34 AM
tony7626's Avatar
Default shift linkage on a cable tranny?
okay, so i picked up a crx with a b16 in it, but i didnt know much about hondas when i got it. im now swapping in a gsr but keeping the tranny. i was told it was a j1 cable. my friend told me it has to be a hydro tranny because of the linkage. the block it stamped B16A 1210674.
and on the tranny there is a sticker that says A1-1014331. and the head is stamped pr3-2. Im so confused i tried to search but no luck. anyone know motor/tranny i have. is there any other markings that could help me determine what is what? head stamp is from a 91.
Old Jan 22, 2010 | 10:41 AM
D16SiHatch's Avatar
Default Re: shift linkage on a cable tranny?
ok that was mildly confusing to say the least.. but i think you're trying to figure out if the shift linkage differs between the 2 trans you have and if they are different when switching to a hydro trans. they are not. doesn't matter what type of b-series 5 speed tranny it is, they will all use the same b-series into ef shift linkage
Old Jan 22, 2010 | 11:32 AM
frank_el_tanke's Avatar
it seems you have the first gen. b16a and an A1 Cable transmission. The shift linkage that came with the crx will work fine with any B-series transmission you decide to put in.
now, when you order a clutch kit make sure you order one for 90-93.
Old Jan 22, 2010 | 01:40 PM
import-tooner's Avatar
I made a similar post today on this topic. Everyone is telling me that you have to get an aftermarket shift linkage like the one from hasport or get one from a DA integra and shorten it but cutting and re welding it.
Old Jan 22, 2010 | 03:56 PM
beansandrice's Avatar
yes but the OP in this thread already has a Bseries swap in his car. So he already has the modified shift linkage.
If you are going to do a complete swap you have to either buy a Shatsport one or modify one.
EF9_RIDER37
11
Nov 11, 2009 11:34 AM
1992db2
Northern California (Sales)
Aug 16, 2009 11:41 PM
iMPoRT GeeK
Jul 16, 2007 09:15 PM
mrjdm2u
Dec 22, 2005 12:20 AM
DroopyHatch
Feb 20, 2005 11:22 PM
