96 civic wont start
Old Jan 21, 2010 | 06:17 PM
91daINTEGRAda91's Avatar
Default 96 civic wont start
i have a 96 civic hatch automatic i bought it with a bad motor i replace the motor and went to start it and it like spins half a turn than stops and doesnt keep trying than when u stop trying to start it u can hear like a loud air leak like something is pressurized and leaking need help....thanks
Old Jan 21, 2010 | 08:03 PM
fcm's Avatar
fcm
Old Fart
Default Re: 96 civic wont start
Is the "air leaking sound" coming from the intake manifold,[listen at T/B] or from the exhaust manifold, listen at muffler outlet????
Sounds like a valve is not seating properly, cylinder(s) on compression stroke has valve that is leaking, [not seated], intake valve if sound is from intake manifold, exhaust valve if sound is from muffler.
A compression and leak down check should be done, have you checked valve clearance?
How is the mechanical timing, the GSR engine is an interference engine, can engine be rotated past half a turn by hand, are valves running into pistons, a bent valve will not seat properly, insure cam/valve timing is correct.94
B_Swapped93
Nov 12, 2013 06:16 AM
kauai96
May 30, 2009 12:44 PM
patrickvertigo
Mar 10, 2008 04:29 PM
soon2bdropped
May 22, 2007 07:18 PM
boostmywankle
Apr 16, 2004 07:53 PM
