Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
how to remove the front h emblem.??
Old Jan 21, 2010 | 11:44 AM
yujayn's Avatar
Default how to remove the front h emblem.??
hi guys...i have 09 si sedan...and i wanna change my h emblem on the grill can you guys help me to remove it...coz planning to put the type r thing...thanks....
Old Jan 21, 2010 | 01:10 PM
K5^'s Avatar
K5^
Brand New
Default Re: how to remove the front h emblem.??
Floss and a blow dryer.
Old Jan 21, 2010 | 04:27 PM
yujayn's Avatar
for the front emblem...????
Old Jan 21, 2010 | 04:36 PM
EdithS's Avatar
New User
x2. Just be patient.
Old Jan 22, 2010 | 12:18 PM
peeta's Avatar
you have to take off your front bumper. there are 2 screws that hold the emblem on the back
Old Jan 22, 2010 | 04:58 PM
yujayn's Avatar
cool thanks..that helps a lot...
Old Jan 22, 2010 | 08:29 PM
i-VTEC_DOHC's Avatar
hack saw ftw!
Old Jan 25, 2010 | 09:03 AM
chiggin's Avatar
Attach one end of a length of string to the emblem and the other end to something stationary in front of your car. Put the car in reverse and gun it.....emblem removed!
Just kidding.....what peeta said. I've taken one off before and it isn't hard at all.
Old Jan 25, 2010 | 09:10 AM
K5^'s Avatar
K5^
Brand New
My bad, I thought you meant rear emblem.
Old Jan 25, 2010 | 11:06 AM
hovic00's Avatar
You have to take off the front bumper, then there are a couple screws you have to take off. After that I actually just broke my factory emblem into about three or four pieces to get it off and thats about it. gl
Old Jan 28, 2010 | 04:42 AM
chiggin's Avatar
You don't need floss and a blow dryer for the rear 'H' emblem either. There are 2 clips on the top and bottom that you push out from the inside of the trunk.
Old Jan 29, 2010 | 05:15 PM
Tokyosmash!'s Avatar
Tickle-shits
Community Builder
Community Influencer
Doubtful, you didnt have to on 06-08's
Old Jan 29, 2010 | 06:37 PM
bigearmorfin's Avatar
well on a 07 fg2....
you have to remove the front bumper.
i believe there will be 2 rivets on the corners and 2 pop-up rivets in the middle of the plastic cooling plate.
then you have to take off a good number number of rivets from the front under body and a few on/near wheel fender.
then use an alan wrench to remove two front screws.
then, wiggle off the front bumper (note: be careful with the clipped corners near the headlights)
finally, once the front end is off, unscrew the two screws holding the emblem down...
this might not be completely correlate with an 09 sedan but i think there pretty similar....
if so, hope this breaks it down for u.
gl
Old Jan 29, 2010 | 07:32 PM
SeanZ0r's Avatar
Old Jan 29, 2010 | 11:41 PM
peeta's Avatar
unless you want to break the clips, then yeah you do.
Old Jan 31, 2010 | 12:53 AM
rileyrat's Avatar
The H emblems are held on with clips. Like peeta said you just remove your front bumper and grille for the front H and Si badge. The rear H is accessible from inside the trunk. All other badges are held on with double sided tape.
InTeGrA_bLazEd
Feb 27, 2007 10:37 AM
neptune_
Feb 15, 2006 06:46 AM
AceP97
Apr 3, 2002 09:33 AM
Lo-Buck EF
Dec 21, 2001 03:31 PM
Lewd Lude
Jun 22, 2001 02:46 AM
