90 Si w/B18C, New Dizzy still getting Code 8...WTF
Old Jan 21, 2010 | 09:21 AM
WhiteSTi's Avatar
Default 90 Si w/B18C, New Dizzy still getting Code 8 & 9...WTF
I just finished my swap and fired her up Monday evening. I first got a code 8, it didn't want to idle right. It idled very low and would die. I had an LS dizzy laying around, so I swapped the TDC sensor out. Next time starting it, it idles very high, above 3k and climbing. This time I get a code 9. So I figured, after doing some reading and making a few phone calls, my dizzy is bad. I picked up a new one and installed it last night. First crank, it fires up, idles high still and a code 8. TDC sensor. I don't know what the hell is wrong. Any ideas?
Old Jan 21, 2010 | 09:47 AM
grog's Avatar
Default Re: 90 Si w/B18C, New Dizzy still getting Code 8...WTF
Did you do the wiring yourself or did you buy a harness?
It sounds like a possible wiring problem.
Old Jan 21, 2010 | 10:06 AM
WhiteSTi's Avatar
It's a Rywire harness. OBD2 engine converted to run on OBD1 P72 ECU...
Old Jan 21, 2010 | 10:36 AM
fourthgenhatchB17's Avatar
You need to do continuity tests on the TDC wires to and from the ecu, and at the same time making sure the pins are plugged into their respective spots at the ecu. In fact, do this for all of the distributor wires. Also, make sure all of the wire colors match each other (on each side of the plug) at the distributor. Those wires all look very similar to each other with only a trace of color on them making the difference...basically its very easy to mismatch wires there.
The fact that your engine is obd2 has almost nothing to do with what jumper you used. Its really not a big deal.
Old Jan 21, 2010 | 10:40 AM
WhiteSTi's Avatar
I had already planned on testing those wires tonight after work. I guess if those check out, then what? The dizzy I just bought is defective too...?
Old Jan 21, 2010 | 12:00 PM
I'd say just test the wires. One step at a time. Anything is possible. Where did you get the distributor from?
Old Jan 21, 2010 | 12:07 PM
WhiteSTi's Avatar
It's a reman from Advance Auto
Old Jan 22, 2010 | 06:39 AM
WhiteSTi's Avatar
Well, the continuity on the distributor circuits are good. I'm still getting the Code 9. Cylinder 1 Position Sensor. Plus it still wants to idle a 4k. I have no clue what's wrong or how to fix it.....
Old Jan 22, 2010 | 10:39 AM
So you've checked continuity, now check if the pins are in the right spot at the ecu. Pinouts can be found all over..just google it and search. Trace the wires back thru the jumper and to the ecu.
You are experiencing 2 different codes when swapping distributors (code 8 and 9)? IMO, I'd be more inclined to trust a used oem Honda distributor than one from Advance.
Old Jan 22, 2010 | 10:45 AM
WhiteSTi's Avatar
Yep, the pins were checked as well. They were where they're supposed to be. And I've been hearing a lot about the hit or miss quality of the re manufactured dizzys and other parts from the national parts chains. But I don't know if the dizzy and the codes that it's throwing would be the cause of the 4k rpm idle...
Old Jan 22, 2010 | 12:04 PM
May be related, may not. Code fixed first, then worry about the idle. there are a few things on mechanical related that can cause a high idle as well.
Im sure you can warranty exchange for another distributor right? If you get the same code with the next one, chances are you have a wiring issue and you overlooked something.
Old Jan 22, 2010 | 12:22 PM
EJ1_Sleeper's Avatar
double check to make sure your jumper harness is right. i have a rywire and i was getting a CPK code turned out the obd0-obd1 harness was wrong from the obd0 side they were running to empty ports on the obd1 side. 2 of my wires on the dizzy plug were also reversed (common mistake with old wiring)
Old Jan 28, 2010 | 04:05 AM
WhiteSTi's Avatar
I had that check and was told it was all good. But i'll double check again.
edwinie26
67
Jun 19, 2014 04:50 PM
unsungfate
Engine Management and Tuning
Oct 27, 2010 08:41 PM
redboy183
Jan 1, 2008 07:01 PM
boosted_17
Oct 13, 2007 11:32 AM
zeroek
Apr 20, 2006 01:38 PM
